powar deviator
Post removed..managed to control temps
Looks ok... The number is only relevant during a full load like cinebench R20, so there you have ~102% which is perfectly fine...So I thought I would check to see if evertything looked ok with mine as I am a bit clueless when it comes to power draw etc, I generally leave the bios well alone.
Pic 1 is on idle, reposting over 200%, which i was concerned about to start with.
Pic 2 is during cinebench R20 which shows from 102%-104%
Asus Strix-f x570 mobo installed on an R5-3600
Anyone Help?
You do however have very high load temperatures for a 3600 at 86°C and your idle temps are ~50°C...
For a 3600 I would expect around 70-75°C max for a Cinebench R20 run...
What does your cooling look like??? Is this a prebuilt system?
Perhaps a picture of the internals of your pc?
I was mnore concerned that
Stock cooler atm, no its a custom built, I know the temps are high, I need to play about with the fans a little.
I'm not impressed with the aric silver I have either, think i need a beefier cooler and some better paste.
I was concerned it might be under performing a lot.
Its custom built like all my PCs heat has been an issue since I upgraded, I think due to the stock cooler and the rubbish attic silver Im using its increased.
I want a beefier cooler better thermal paste.
Picture of case below, I’ve removed the lower fan already.
The case fans were running at full speed, and the CPU fans too. The fan curves are set properly, so everything is maxed out, but at full load, it reaches 95°C.gebhaard: What helped me was lowering the vcore (CPU core voltage). What's your vcore typically running at, idle and load? And is your heatsink clean and clear of dust, etc. Is your CPU fan spinning up to accommodate the increases in temperature? If you haven't already, you may want to create a fan curve in your motherboard software for your CPU fan(s), and probably even your case fans. I typically have my CPU fan ramp up along with the CPU temperatures, and have my case fan's curve set to the CPU as well, so that they come up slowly with CPU temperatures (use your heuristics to lag the fans behind herky/jerky CPU jumps in temperature) that way they aren't ramping up and down with every tiny change, but will change gradually with actual longer-term changes in temp.
That is indeed your problem... Best thing to do is to upgrade that cooler asap!
That is a AMD Wraith Stealth I believe???
Noctua has some great coolers, and myself I'm a big 'fan' of the Bequiet Dark Rock coolers, but even a stock AMD Wraith Prism would do much better.
(Depending your budget, there should be a lot of AMD Wraith Prism coolers available secondhand...)
As for thermal compound, I now always use Thermal Grizzly Kryonaut. Great stuff... Dropped my temperatures very significantly compared to the standard stuff...
Honestly, a custom loop is a complete waste of money for a 3600! Why ??? Just for looks ???Ye been looking at Noctua and Be Quiet, as well as the Kraken z63 AIO, but really want a customer loop, but they are expensive, and I need to update my aging RX480 first, awaiting to hear about big Navi before making my decision .
It just means MSI is slightly underreporting the power under full load, so your 3950x will be allowed to draw a bit more power than stock...Hello all ,
Interesting, I read on my R9 3950X on MSI MEG X570 Ace (MS-7C35) BIOS Version 1.92 AGESA Version Combo-AM4 1.0.0.5 this :
94.8 - 95.7 averaging on 94.9 under full load
everything on stock no manual OC applied everything in bios on automatic
So how do I understand this? is it OK or is there some cheating going on by msi ???
Thank you !It just means MSI is slightly underreporting the power under full load, so your 3950x will be allowed to draw a bit more power than stock...
Since this is just ~5% you should not worry, there are other cases where up to 50% of underreporting is happening...
Hi
Just registered and did Cinebench R20 test to give more feedbacks
It’s more of an "elitist" model problem
I voluntarily fled the purchase of high-end motherboards, often prone to numerous problems
CPU : AMD Ryzen 9 3900X
MB : Gigabyte X570 UD ( Rev 1.0, Bios F12f )
Got 101.3% at minimum while benching
Everything at stock voltage but memory @ 1.35V ( 1.36V sensor measured ) for my CMK32GX4M2B3000C15
Regards
Not really, since the most expensive boards aren't the ones doing this, its the cheaper ones particularly in the Asrock branding. $700 Formula and Godlike are in the clear.
I have the latest BIOSInstall the latest BIOS. That's what I had to do. My ASUS board with 3900X was doing the exact same thing.
