Fair, but it's quite the improvement from 67%. Hopefully the remainder gets resolved in the next BIOS update?I wouldn't say that 87.8% is within limits. It's that extra little bit that they hope pushes the benchmarks 0.5 - 1% ahead.
Thanks for the article The Stilt (found from THGs btw), very useful & a bit of an eye opener!
I wonder if this is the reason behind why my stock cooler isn't upto the job of cooling my Ryzen 5 3600 (@ stock) when running distributed computing?
With the stock settings running DC on all 12 threads I was getting temps into the high 80Cs!This is with good case cooling (120mm inlet & exh fans, plus 3 80mm side inlet fans).
In the end I throttled back the CPU to 65w PPT which keeps temps in the mid to high 70Cs (until I fit a better cooler).
So with the above non-stock settings & running a mix of [email protected] & [email protected] I get an average deviation of 97.5% with an average clock speed of 3.69 GHz.
I will test out the stock settings later. I think my rig specs are in my sig (will check in a second).
Am I right in thinking that by lowering the CPU PPT that I may have over ridden any possible false reporting of the CPUs power consumption?
If so, it's a remarkable coincidence that I got so near to 100%!
Under Linpack my reading averaged 127%. I run an MSI MEG X570 ACE ver. 1.80. If I understand the article correctly, MSI is seriously overvolting my cpu, correct? If so, is there any setting I can make to the voltage to lower the overvolt? I currently have the cpu voltage locked at 1.42v as it was pushing over 1.5v on auto. No cpu overclock. No PBO. It happens on Both AMD High Performance Power Plan and the 1usmus Ryzen Power Plan. I have wondered why this cpu seemingly runs so hot when there is an NH_D15 cooler set to full fans on top. This cooler should be well able to keep the 3900X under 70c. The article states outside of certain MSI mobos, the setting isn't available. Can someone tell me if this mobo has it available? And thank you fro bringing this to the forefront.
The 3rd gen. Ryzen CPUs run a bit hot by their nature, due to the advanced 7nm manufacturing process they use.
Smaller the die size is, the harder it is to cool it. Intensity, power dissipation per area. This isn't a AMD specific phenomenon by any means.
First image here is running just idle, I've got my pc in "Quiet" mode even at the time
Meanwhile this second one was taken while running Cinebench R20, as I'm not 100% sure what I'm lookin' at, I can't comment much about that... Hopefully someone can tell me what the hell I'm looking at fully
Here's an image of my Motherboard info taken from HWiNFO
Well, that proves something I suspected with "My 65w processor is too hot" complaints after seeing this thread. Your ASRock board is only reporting to your processor that its only using 50% of power so it uses more, so much more that it is reaching the voltage limit before the 'fake' power limit. No way in hell 88w would yield 90c otherwise.
I wouldn't be surprised if most boards are doing this with the 65w processors actually. Need more subjects.
