Exporting both of my 2 SPD Hub Temperatures can not be done with MSI Afterburner, I only get one sensor to monitor
mahanddeem
I have MSI Afterburner hooked to read data from HWINFO64 via shared memory support . Everything works beautiful like GPU mem temp and CPU vCore, but the only issue I have I can't send BOTH SPD temps to MSI Afterburner. When I "setup" data from HWINFO64 in MSI Afterburner and check both memory channels 1 and 3 SPD temp I end up with only one of them (likely no 1 not 3).
I tried renaming them in HWINFO64 to SPD temp 1 and SPD temp2 but also didn't work.
As a work around it, I use HWNFO64 to send these 2 sensors to RTSS, but this isn't idea and not looking nice in MSI Afterburner OSD.
Please help if I am missing something, or a fix would be appreciated if it is a bug
Thanks
