Fan control API of hp envy 17?
careca
Hi, is there a possiblity of getting the code for the fan control of the hp envy 17? My idea was to use the codes on a simple app made by me in autoit, sort of a model specific fan control. Autoit can be used with api's, if i know the code, i may try.
If that's not possible, could someone point me in the right direction as to how i could do it?
Best regards.
That will require experience with low-level programming, especially Embedded Controller and you'll need to write a driver in order to access it.
If you think you have the required experience, please contact me via e-mail and I'll give you the details.
careca
Hi Martin, thank you for the answer, i think it's way over my head, thought i was simpler, thank you.
