Fan control when HWinfo is not running
BillS
I'm running the 6.20 portable version and have configured a fan control profile.
Does the original OEM/Bios fan control profiles go back into play when HWInfo is not running?
Also, how do I disable the custom fan profile that I created in HWInfo? When I start it, the fan control become active and I would like to disable it.
Thanks!
Yes, when the fan control dialog is terminated, HWiNFO will restore the default system control.
You can disable a custom profile by setting the temperature source to "NONE / OFF".
