Fan control with different speed?
lilw
Hello Martin,
I'm using Alienware 17 R2 2015. In Hwinfo fan control I can use only around 2500 rpm and 5200 rpm. When I leave the fan for my BIOS system to control, I saw it has other speed for the fan like 3000 rpm and 4000 rpm. I wonder is it possible to let Hwinfo control the fan speed like the system?
This depends on the fan control mode used. If you have "EC support" enabled in HWiNFO and see the Compal sensor, other levels might be available, but this mode can cause issues. This has been discussed several times here, or on the Tech|Inferno forum.
