I recently installed hwinfo32 on my Dell Precision M65.
It's working great but I have one problem.
I have hwinfo set to start automatically and to start sensors automatically and show them (Dell EC Cpu and Gpu and the FX 350M GPU temp) in the Systray.
However I can't get the Fan to show automatically in the systray.
The Fan icon won't show in the Sensors list under Dell EC unless I do something to cause either the CPU or GPU, which I am both monitoring with Custom Auto in the Fan Contro,l to raise a temp to the 1st fan speed threshhold in my list. For example if I open Display Properties and choose Screen Saver and the 3D Flowerbox and do a Preview for approx 20 - 30 second to raise the GPU temp to 50c (which will trigger the Fan to come on at 2400rpm then at that point the Fan icon will become visible in the Dell EC sensor section and I can then right-click it tell it to Add to Systray.
Is there a way to have the Fan Status automatically be added to the systray like the Dell EC Cpu and Gpu and the FX 350M GPU temp sensors are?
P.S. I'm adding an attachment of my Fan control settings.
Thanks,
Paul
Thanks,
Paul
