Gigabyte Z590 Gaming X (wrong sensor info)
referer
Hello there! First of all - thank you for this program, using for several years :cool:!
Gigabyte Z590 Gaming X, there are some sensors with wrong readouts:
Temperature 5 (it's CPU VRM Temp);
+3.3V shows wrong value (2.004V, +/- the same as Vccp2);
+5V shows value from +3.3V sensor;
+12V shows very wrong value (0.096V);
VR In shows 11.840V (i think it's crazy voltage :eek:).
Look on attached screenshot file (i marked these sensors - in BLUE)!
* Yellows are what i need...
Thanks for the report, shall be fixed in the next build so that the full and correct sensor layout will be displayed.
referer
I found a new problem there.
Intel® Core™ i9-10910 (yes, i9 10910 CPU from Apple PC).
Core Usages (shows a mystical number);
Max CPU/Thread Usage (does not calculate the amount, but shows the largest value of one core - random max used one core);
Total CPU Usage (shows the same mystical number what Core Usage show).
Those values are correct, you're just missing their meaning. By default all sensor items have tooltips that will tell you more details about the meaning. Have you read that?
referer
OMG :eek:, i have to play games less... o_O
Thanks, Martin :p
