GIGABYTE Z690M AORUS ELITE AX DDR4 Renesas RAA229131 Sensor
tecklord
Hi!
I have a unusual issue with monitoring, as I have the same mainboard 3 times (Gigabyte Z690M AORUS Elite AX DDR4 / 2x Rev. 1.0 and 1x 1.1)
But only on 1 the monitoring of the RAA229131 is shown and I have no idea how to enable this on the other systems..
Is there something known?
Or what can I do?
Thanks
Sebastian
It could be due to a different VRM used but to be sure please attach the HWiNFO Debug Files from all those systems for analysis.
Hi!
Attached both debug protocol's (_RA with sensors _nR without)
Thanks!
  • HWiNFO64_RA.7z
  • HWiNFO64_noR.7z
I can see that the VRM in NoR isn't responding. This might be because there's a different VRM used on that board. What is the difference between them, board revision?
It might be interesting to check on the mainboard what VRM/PWMs are used but that would probably require removing the VRM heatsinks.
I will also check with GIGABYTE...
Hi!
nR is Rev. 1.1
RA is Rev. 1.0
... both are small builds... not going to take them apart any soon - as I've upgraded to 13600K last week only
But thanks!
Thanks, that could be the culprit - maybe a slightly different design/layout. Waiting for response from GIGABYTE..
