Hello there, I'm trying to get sensor info for a Supermicro system but while it's running the "Analyzing XTU" step the system hard resets, there is no bluescreen. This happens consistently at the same point each time I try to run the program. I've already tried to disable some options found in similar threads like SMBus Support, SW SMI and ACPI Enumeration but unfortunately the result is the same. I've attached a DBG file (with with default settings but Debug Write Direct enabled) and below are the specs of the system.
HWiNFO64 7.44-5100
Motherboard: Supermicro Super H13SSW
CPU: AMD EPYC 9354P
Memory: Micron MTC40F2046S1RC48BA1
SSD: Samsung PM9A3
OS: Windows Server 2022
If anyone could point me in the right direction that would be appreciated. And if any more info is required, let me know.
HWiNFO64 7.44-5100
CPU: AMD EPYC 9354P
SSD: Samsung PM9A3
