[HELP] Constant random crashes - HWinfo error posted
Schoenin
Log Name: System
Source: Service Control Manager
Date: 8/21/2020 12:00:47 AM
Event ID: 7026
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: 1070ti
Description:
The following boot-start or system-start driver(s) failed to load:
HWiNFO
HWiNFO32
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" />
<EventID Qualifiers="49152">7026</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8080000000000000</Keywords>
<TimeCreated SystemTime="2020-08-21T04:00:47.300819000Z" />
<EventRecordID>373027</EventRecordID>
<Correlation />
<Execution ProcessID="620" ThreadID="624" />
<Channel>System</Channel>
<Computer>1070ti</Computer>
<Security />
</System>
<EventData>
<Data Name="param1">
HWiNFO
HWiNFO32</Data>
</EventData>
</Event>
Constant random crashes. Thought I was good after install/reinstall of hwinfo32/64. Nope 4hrs of gaming just fine, 5 mins afk and it crashes....
Have possibly narrowed it down to HWinfo as a source? Anything you need to know that could help you help me?
I have searched Device manager for ASmedia and found none.
Possibly associated with this error -
Log Name: System
Source: Microsoft-Windows-Kernel-PnP
Date: 8/20/2020 6:10:59 PM
Event ID: 219
Task Category: (212)
Level: Warning
Keywords:
User: SYSTEM
Computer: 1070ti
Description:
The driver \Driver\axb610t8 failed to load for the device PCI\VEN_1095&DEV_3112&SUBSYS_39584BE8&REV_01\4&5d18f2df&0.
Event Xml:
<System>
<Provider Name="Microsoft-Windows-Kernel-PnP" Guid="{9C205A39-1250-487D-ABD7-E831C6290539}" />
<EventID>219</EventID>
<Level>3</Level>
<Task>212</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2020-08-20T22:10:59.771211000Z" />
<EventRecordID>372765</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="108" />
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="DriverNameLength">57</Data>
<Data Name="DriverName">PCI\VEN_1095&amp;DEV_3112&amp;SUBSYS_39584BE8&amp;REV_01\4&amp;5d18f2df&amp;0</Data>
<Data Name="Status">3221226092</Data>
<Data Name="FailureNameLength">16</Data>
<Data Name="FailureName">\Driver\axb610t8</Data>
<Data Name="Version">0</Data>
</EventData>
</Event>
Edit: And now I've crashed and posted a report.
The attached HWiNFO Debug File doesn't indicate any issue inside. It was closed properly. Can you try to generate one while the system crashes?
That file is 14MB and again doesn't indicate any crash during HWiNFO runtime. Are you sure the problem is caused by HWiNFO?
