High CPU temps, should I worry/take action?
kurikuri
hello hello!
When rendering heavy files from After effects, some CPU values report in the red.
I was wondering, if I should take any action, if these numbers are about to damage or so?
The reds in the first 4 values happened during the render multiple times, for short moments.
The 71% min. value from '' Power Reporting Deviation '', happened once in the end of the render as far as I could see.
Thanks in advance!
Those numbers aren't critically high but they will likely trigger thermal throttling.
It might be good to improve the cooling.
