As the title says: the most serious issue I had with it was when setting the hotkey to Num-0. It works in-game as a toggle, as you'd expect, however it seems to disable the key otherwise. That is, I hit the key in whatever text field in Windows, and it's like the key is dead. Doesn't make a '0'.
I took my keyboard apart yesterday because I thought it was a hardware issue(!). :-/
Now I can't help but chuckle a little when I've just realized that it's a bug with HWiNFO (I used to use MSI Afterburner with this same install of RTSS, and this didn't happen, so it's probably not an RTSS issue per se).
Hey, at least the keyboard isn't broken, and it did need a cleaning anyway.
Changing the hotkey to CTRL+Num-0 works in-game to toggle the OSD,AND more importantly, it works out-of-game as it's supposed to Edit2: Actually, it steals that hotkey combo also so that you can't use it anywhere else.
Another issue with the hotkeys is that using CTRL+ALT-(Any Key) doesn't seem to work. It'll allow you to set it, but it won't toggle the display.
I tried to use my old hotkey of CTRL+ALT+Num-* initially, it didn't work, and I forgot about it until the other day when I tried a different key combination (Num 0), which did work. Forgot about it until yesterday I realize hitting Num-0 wasn't outputting anything while typing, and thus my keyboard vivisection.
FWIW, running Win7 x64, latest non-beta of HWiNFO, latest RTSS. Let me know if you need any more info from me.
Hope you can sort it out, and thanks for the great app! The RTSS integration is excellent otherwise. Really like the labeling and organizational abilities.
Edit1: Not to be nit-picky, but I thought I'd mention it as it *may* be related, and is at least on the same topic: response of RTSS to the hotkey is... sluggish at best, and seems to vary in response time depending on what hotkey combo is set (though that last part may be coincidence or something). Takes a second or two, typically, before the display toggles on and off after I've hit the key (combo).
