How to remove Corsair Axi monitoring in HWinfo64
Cavokk
Hi forum.
I have recently replaced my trusty Corsair Hx850i PSU (that worked flawlessly with HWINFO64) with a Ax1600i but to my surprise it bugs HWinfo64 monitoring. And yes I have seen all the posts on this being a Corsair issue so I just want to disable the Axi monitoring support in HWinfo64. I seen several screenshots of options where you can deselect asetek/Axi monitoring under "Security" tab in HWinfo64 options but I simply cannot find it - I only have the following tabs in the latest beta version:
It seems that there is no solution for monitoring the Corsair flagship PSU in HWinfo64 and I therefore ask for a solution to at least disable the monitoring of it in HWinfo64 without unplugging the USB cable. The Corsair tools iCue and Link works flawlessly for monitoring the PSU parameters but i really just want ONE monitoring tool and its unlucky that HWinfo64 bugs out with 10 sec update interval and generally hangs..... :( ......
I have tried with all combinations like iCue installed, iCue and Link installed and none of them installed - all 3scenarios with more or less the same behavior..
Thanks in advance for any help as its probably me missing the obvious :D .
Cheers
C
To disable monitoring of Corsair devices you need to go into the main Settings window.
If HWiNFO is already running, right-click the HWiNFO icon in notification area (tray) to reach that.
Cavokk
ahhh there it was - found it - I knew it was a blunder on my side ;)
And yes now its back to normal 1 sec refresh without the Ax1600i showing and messing up.
Thanks for the help and thank you Martin for the awesome tool you provide to us :D - would be awesome if we could get the Ax1600i working but I guess its a dead end based on your efforts with Corsair not responding.
All the best..
C
