hwinfo ddr5 dimm crazy voltages
visualizer
While I was using my computer I wanted to check the temps when I clicked it showed ram voltages at all parameters as 3.33V and the temperature was not showing. Also, PMIC high temperature was YES . The computer didn't crash and it showed no issues. Unfortunately, I didn't take a screenshot but as I said voltage everywhere was 3.33V . Also after a few seconds both DIMMS disappeared from hwinfo.
This is a bug right? isn't possible to feed ram such voltages without damaging it correct?
Anyway after I restarted the computer everything was showing correctly.
RAM KINGSTON KF552C36BBE-16 FURY BEAST 16GB DDR5 5200MHZ
32 total
Z790 GAMING X AX (rev.1.x) Gigabyte
Are you perhaps using some other monitoring, tweaking or RGB control software along with HWiNFO?
If yes, then it's most likely due to a conflict between them.
