The second debug data you attached indicates a hang during Namtai Wbuzz scan.
Perhaps the problem is rather in USB Host/Hub to which these devices are connected.
I see. Damn, if it weren't for the fact that when the program freezes, I have to reset my PC because all the shortcuts and task manager don't work and they don't close the program, I would play with unplugging and connecting each device if it was possible to force the program to close like that ;(
It's a pity because it's not an ordinary cheap hub, sadly
Well, if I knew what program I could use to open this file, debug + how to read it, I wouldn't bother and I would calmly disconnect and connect everything one by one.
Edit:
Strange thing, I disconnected the entire hub and connected it again, except that I turned off each device (hub with switches) and turned on each device + program one by one.
Almost all devices do not suspend the program, even Buzz, etc., until I connect Megalodon, then even if I disconnect it, other devices cause problems until I disconnect the hub and connect it, so it turns out what was said first. Megalodon causes havoc rrrrrrrr
Edit edit
It is served after
x when I run the program, it crashed again, this time on the sound card, strangely enough, when I disconnect the hub, the program starts, so I don't know, the hub mixes but only in this program it's sad
