MonstroMart
Hi!
First i want to thank you for this great little app that is HWiNFO. The g15 lcd support is first class. Good job.
I have 3 questions to ask. Hope you'll be able to find the time to answer them.
1. As you can see in the picture under my total CPU usage while running HWiNFO is always 15% with one core at 50% all the time. I have nothing else running but HWiNFO and the common OS services and drivers. When i close HWiNFO my total cpu usage goes back to 0~1%. Is it normal ? It makes reading of idle temp almost impossible.
2. Is there a reason for the g15 lcd options to feature 3 lines only? With a font size of 9 i could have 5 lines and CoreTemp g15 plugin does feature 5 lines.
3. n00b question here you can laugh at me
the reason why i download this great little app is that i plan to enable xmp profile in my bios to run my ram at the maximum speed. Of course enabling xmp in my bios will overclock the fsb and will also overlock the cpu a little bit unless i turn off turbo mode. I have good vent in my system. Antec 900 case with 6 fans, custom cpu (not installed yet) and gpu cooler so i should be fine. But i still want to monitor temp via the g15 lcd screen for a while. My problem is in the picture under i can't figure out what is the mb chipset temp lol. There's a total of 5 mb sensors. W83667HG Motherboard, CPU and Aux. I figure the cpu sensor is one close to the CPU (report same temp as the cpu), i don't have any clue what the aux sensor is and the MB sensor report almost the same temp as the cpu so not sure about this one looks a little bit high to be the chipset temp with only HWiNFO running. Then there's 2 ASUS P7P55D EC sensor. One labeled as CPU with a temp that doesn't make any sense considering the CPU is at 15% load. And another one labeled as motherboard that looks to be ambient temp in the case. Anyone can help me figure out what is what and label them accordinly ?
Ty for the help and keep the good work.
