I'm sorry but the attached Debug File is not valid. I suppose you have again started HWiNFO to disable Debug Mode which has overwritten the file.
Please create a new one and attach it before starting HWiNFO again.
This seems to be an issue of the Intel GPU driver - it behaves quite erratic.
What Intel GPU driver version do you have installed?
Try to upgrade the driver if that will help.
Go into Device Manager - Display adapters. Check the Driver properties to determine actual version first and try to Update Driver if there's a new version.
Thank you very much. The problem has been resolved. After updating the Intel driver, the drawback is that there are two more programs in the background XD
I have submitted this bug to the Intel AXG team and they need the driver version that was causing the issue to have a look at that.
It would be great if you could somehow retrieve the previous Intel Graphics driver version that was causing this problem.
