HWiNFO64 not responding while 'Analyzing PCI Bus'
Mikelogamer
The title says it all. Just downloaded and installed the program but it almost immediatly goes to a not responding state at the 'Analyzing PCI Bus' step. Eventually after 1-3 min my whole pc will freeze and I have to perform a hard reset.
I'm running the program on a fresh W10 Pro x64 (fully updated).
Any solutions? I enclosed the DBG file.
There seems to be a problem with OpenCL (part of GPU drivers).
Which version of AMD Crimson drivers is installed? Can you try to upgrade to the latest version?
Thanks for the quick response! I'm at crimson 18.4.1 so I'm up-to-date
Well, then the problem might lie in those drivers.
Try to disable the "Wake disabled GPUs" option in HWiNFO, that might provide a workaround for this case.
That worked! Thanks a lot! (Sorry posted the dbg a bit to soon, it just took a while loading everthing this time)
That points to just another problem with the GPUs. Is the machine and especially GPUs running stable?
Have you tried to use/load all GPUs using some other applications?
