HWInfo64 shows WHEA (PCI/PCI-E) Errors
Hey, purchased a brand new computer and works fine and runs game perfectly.
I was monitoring my CPU temps using "HWInfo64", and noticed there are errors reported under "Windows Hardware Errors(WHEA)", specifically, under "PCI/PCIE Bus Errors".
The errors keeps rising by the minute.
I think it's this one:
I browsed the "EventViewer" and noticed that there are Warnings reported from the WHEA logger, on a specific PCI device:
A corrected hardware error has occurred.Component: PCI Express Root PortError Source: Advanced Error Reporting (PCI Express)Primary Bus:Device:Function: 0x0:0x6:0x0Secondary Bus:Device:Function: 0x0:0x0:0x0Primary Device Name:pCI\VEN_8086&DEV_A74D&SUBSYS_00000000&REV_01Secondary Device Name:
Not sure what this device is, or whether it is correlated to the errors I'm seeing in HWInfo, but I think it is. All the warnings come from this device. I'm not experiencing any issues on my computer so far (being a day), but these Warnings are bugging me.
Will appreciate any help, Thanks!
This is just the PCIe bridge, you need to check the device located beneath it. That's most likely causing the problems.
There are several threads about these issues here. Some people solved such problems by disabling PCIe Link State Power Management (ASPM) in BIOS.
