HWinfo64 svm detection
wawans1975
HWinfo64 detects my CPU as no svm function, although i have enabled SVM at BIOS. Is this HWinfo64 bug?
Windows Sandbox tested running btw.
Thanks.
Edit: CPU-Z has not detected AMD-V either  :huh:
I don't think this is a bug in HWiNFO, it should be showing this properly and I verified it many times.
wawans1975
my other machine (using r7 1700, b450 i gbyte, latest BIOS) not showing svm either.. probably windows prevent your software then?
wawans1975
Can you verify with some other tools?
currently im runing older machine (kaveri, bios not updated,  just windows), samething svm not listed, but i can creat virtual machine using hyper-v manager from windows, installling windows on vm now..
Can you check detailed features in the main window, especially "Secure Virtual Machine" ?
wawans1975
only these from my kaveri desktop's Settings app> Update & Security Page > Windows Security Page:
wawans1975
I just turned off SVM at BIOS,  AMD-V appeared then  and 'Secure virtual machine' present  :huh:
AMD-V in read means the feature is supported but disabled at BIOS level.
That's strange and looks like BIOS would be doing things upside down - with SVM enabled the system reports it's not supported.
Dalai
Anti-virus software can "block" the virtualization features of modern processors, meaning that they use it for themselves so other software can't use it. Avast is known to do something like this (had a case with their Free Antivirus and VMware/VirtualBox some time ago). I can imagine that the OS can do something similar which prevents applications to use, or even see, virtualization.
Regards
Dalai
