paradoxum
For some reason, my DIMM Temp sensors do not work in AIDA64, but they work fine in HWiNFO, and I can also grab the temp sensor from the XT Pro with it - but it causes my RGB to go on/off every 2 seconds.
I'm exporting the values to RTSS OSD, and like I say I can't use AIDA because it won't support my DIMM sensors but HWiNFO causes the flickering, and I need to run icue or the RGB isn't set properly and the fan cooling curve based on my water temp sensor I also think doesn't work, is there no way around it, like somehow even block the iCUE app from reading the sensor itself and causing the conflict by modifying a file? I was deleting threads from hwinfo in process explorer related to icue to see if I could find a specific one that would stop the flicker when terminated but no cigar.
Thanks. If I can get this working I'll be buying a license so I can share the values longer than 12hrs for my OSD.
Streamable
streamable.com
