Is it normal for audio to stutter when starting Hwinfo?
Chopkinsca
When I start the program up and select sensors only, I get a sound stutter when things are loading. It is the same kind of audio when a blue screen happens. I'm on 7.20. Probably sounds stupid to ask this question, but I'm paranoid and anxious.
Such stutter might happen if some hardware interfaces are accessed directly and/or at higher priority. If this happens only at startup and not constantly during runtime then it's OK.
PiersJH
Do you have Nahamic software installed? You can use Task Scheduler or Services to check.
PiersJH
Nope, I do not.
That's rare to see these days, as it appears every vendor is using A-volute and Nahamic. What Martin's said makes complete sense, and you could use LatencyMon to watch as HWiNFO starts in sensor-only view. And by sound, I'm assuming you have music playing?
Chopkinsca
Yeah, when I have music playing. I didn't think to check LatencyMon while loading up hwinfo
