Issue with Remote Sensor Monitor
solber
Hi, I don't really if it's the right place but I'm facing an issue for no apparent reason since some days, I'm trying to run Remote Sensor Monitor 2.1.0 but I keep having the same issue :
Please wait for the web server to start.....
Unhandled Exception: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Net.HttpListenerException: The process cannot access the file because it is being used by another process
at System.Net.HttpListener.AddAllPrefixes()
at System.Net.HttpListener.Start()
at Microsoft.Owin.Host.HttpListener.OwinHttpListener.Start(HttpListener listener, Func`2 appFunc, IList`1 addresses, IDictionary`2 capabilities, Func`2 loggerFactory)
at Microsoft.Owin.Host.HttpListener.OwinServerFactory.Create(Func`2 app, IDictionary`2 properties)
--- End of inner exception stack trace ---
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Microsoft.Owin.Hosting.ServerFactory.ServerFactoryAdapter.Create(IAppBuilder builder)
at Microsoft.Owin.Hosting.Engine.HostingEngine.StartServer(StartContext context)
at Microsoft.Owin.Hosting.Engine.HostingEngine.Start(StartContext context)
at Microsoft.Owin.Hosting.Starter.DirectHostingStarter.Start(StartOptions options)
at Microsoft.Owin.Hosting.Starter.HostingStarter.Start(StartOptions options)
at Microsoft.Owin.Hosting.WebApp.StartImplementation(IServiceProvider services, StartOptions options)
at Microsoft.Owin.Hosting.WebApp.Start(StartOptions options)
at Microsoft.Owin.Hosting.WebApp.Start[TStartup](StartOptions options)
at RemoteSensorMonitor.Program.Main(String[] args)
I'm runing the .exe using this command :
"Remote Sensor Monitor.exe" --hwinfo=1 --gpuz=0 --aida64=0 --ohm=0
I've not changed neither anything in the folder, nor hwinfo.
Thanks if you find my issue !
