Limit Export of Sensor Logging
boston.george
Hi everyone
I've recently asked myself if it would be possible to select specific sensors for the sensor logging csv?
I was able to customize my view in the hwinfo GUI but the csv hast still all the available sensors reported.
Have a great day,
George
Sorry, no. There's no filter for sensor logging.
You might try to disable monitoring of values, which you don't need and those should not be included in the log.
TomWoB
But Martin ... I think this is exact what boston.george ist looking for (or I'm wrong?):
Which sensor is logged depends on the configuration of:
  • HWINFO64 Sensor Settings
  • Layout
  • Monitoring CheckBox (of any sensor):
     - YES: sensor is logged
     - NO:  sensor is not logged
Example: if you uncheck the "Monitoring" CheckBox of "Physical Memory Used" -> sensor is not longer part of the "sensor logging csv":
[attachment=3138]
