No - without documentation or some information about the new LSI libs it's impossible. I'm unable to find this anywhere, most likely it's not public.
Hello Martin,
We are currently using 4 servers with RAID controllers and would like to read and log the Smart values with Hwinfo.
Is this feature going to be integrated into HWiNFO or can it be solved similarly to the previous case using support libraries and a beta version?
Two of the servers are equipped with AVAGO MR9460-8i (MegaRaid) drives and the other two with DELL PERC H330 Mini drives.
HD Sentinel can read the values without any issues.
Best regards.
Only simple info not show temperature.
How to show temperature ?
My Perc H710P
Thanks but I'm afraid it doesn't help much. I can see the raw data returned from LSI libraries but it's lacking the interface definitions which I believe have changed in later versions.
The whole culprit must be in some LSI SDK which I'm unfortunately unable to find anywhere, at least the new version.
