Memory Junction Temp Not Appearing for EVGA 3090
nassalone
I am wondering if anyone else is having this issue. You can see in the attachment the junction temp is not showing up.
Cheers,
Nick
Was this value shown before, did you perhaps update the NVIDIA drivers when it stopped showing it?
Also please attach the HWiNFO Debug File with sensor data so I can see in more detail why it's missing.
Owmince
reset your order in your setting it should appear after then. I had the same problem after dragging the line out of the software, it vanished
nassalone
@Martin @Owmince - Owmince's advice worked. Thank you both for responding and sorry for the late response... just got around to playing around w/ the 3090 more!
I think the software got confused b/c i was switching GPU's around so much and resetting it gave me the correct settings.
Best,
Nick
