Memory modules not shown
vossibaer8
I'm using HWinfo quite a while just for checking my hardware. It looks like one off the many updates in Win10 braught up this flaw:
In System Summary there are no memory modules to select.
The modules used are Patriot Viper 4, DDR4-2400, CL15-15-15-35.
Regards
Jens
It looks like your memory modules might have damaged SPD memory and that's the reason why HWiNFO doesn't recognize it. Some of the entries required contain invalid values.
You might try to check them with Thaiphoon Burner what that will say.
Anyway, I will add a workaround for this in the next build of HWiNFO.
Are you perhaps using RGB lightning? Such damage to DIMM SPD was usually caused by tools controlling RGB lightning.
vossibaer8
First of all, Bitdefender prevented Thaiphoon from running :-(
I'm not using any lightning in my PC. I attached the output of Thaiphoon burner.
