MMX benchmark indicate a very low score
tma86
here my report:
(i don't know why bios is not recognize my CPU L2 cache?...)
When i ran benchmark part, all is OK but only one:
score mmx is: 55853 less as a core2duo T7400 but i have C2Q 9650...
what do you think about that??
thx bye
  • test.7z
Have you run the test in Multi-threaded mode?
If yes, there already seem to be issues with MMX score under Windows 7, but the reason is still unkown.
tma86 said:
here my report:
thx bye
tma86
Hi, thx for quick reply...
Yes i use multi-thread bench.
i post the debug file, i hope will help you a little bit.
Regards
  • HWiNFO32.7z
tma86
hi you can see in attach files the report and debug with the hw32_345_677.zip.
For me GPU temp and clock are OK (according to ati overdrive) because the GPU underclock to
400Mhz in 2D mode and have a step to 600Mhz i think and 850MHZ in full load in 3D.
  • Desktop.7z
Looks ok to me now.
Thanks for the feedback.
Temmy
I also have this effect MMX is a lot lower with Win7
Dual Core T2390 1.86 GHz
WinXP(prof) -- Win7 (business)
CPU 38706 -- 45909
FPU 28178 -- 28092
MMX 57666 -- 17639
Memory 1741 -- 1766
Disk is not comparable - 2 dif. HDs :oops:
I did 2 more runs for the atachments (sorry)
  • HWiNFO32.zip
-Z-
Hi. I have Fujitsu v6535 on GL40 under windows 10 14965. Today have changed CPU to T9500 and HWINFO 5.42-3050 shows very low MMX bench. 4 times lower than expected. Is it software problem beacuse of win 10 or no?
Thanx.
Dont know is it important or not, but if i start under win10 in virtualbox win xp and there start hwinfo i can see wrong cpu (it is clear) but with higher mmx bench than in win10.
