MSI G41TM-P33 incorrect reading voltage chip FINTEK F71889
VictorVG
I found than HWiNFO32 3.60/3.60.973 and Lavalys Everest 5.50.2253 beta incorrect read power sensors +5V and +12V. BIOS read this sensors true. I check use digital multimetr MASTECH M320 (class 0.5). Found:
+5V sensor:
BIOS ~ 4.96V, multimetr +5.024V, but HWiNFO32 read this sensor data as +3,70V (???)
+12V sensor:
BIOS ~ 11.944V, multimetr +12.147V, but HWiNFO32 read this sensor data as +6,25V (???)
Reports attached
Link on FINTEK Super I/O chip manual:
<!-- m --><a class="postlink" href="http://www.fintek.com.tw/files/productfiles/F71889_V0.28P.pdf">http://www.fintek.com.tw/files/productf ... V0.28P.pdf</a><!-- m --> - full manual
<!-- m --><a class="postlink" href="http://www.fintek.com.tw/files/productfiles/F71889_ab.pdf">http://www.fintek.com.tw/files/productf ... 889_ab.pdf</a><!-- m --> - about chip press release
  • Reports_and_chip_manual.rar
Re: MSI G41TM-P33 incorrect reading voltage chip FINTEK F718
Every mainboard needs special adjustments since they use different connected sensors (it's not an issue of Fintek sensor support).
Please attach a full HWiNFO32 Report and Debug File including sensor data, then I'll try to adjust the values.
Ok! Welcome. I get to the house and went out. Now I went from a friend, because simply unable to report on the observation ...
Additional. I send required information:
debuglog.htm
HWiNFO32.DBG
HWiNFO32.INI
Standard.htm
debug log, configuration data and perfomance test for reference information.:)
  • debuglog.rar
Thanks for the data. Unfortunately you didn't include the Sensor data in those reports. Please make sure you open the Sensors window and then save the Report (+DBG) and submit again.
Ok! I added information:
COLUMBIA.LOG
HWiNFO32.DBG
HWiNFO32.INI
sensors.CSV
sensorslog.CSV
Standard.htm
sorry, my multimeter M320 can't send data to PC - this is portable digital Amper-Volt-Omm meter, class 0,5% ±1 digit, 3,5 digit...
  • sensors.rar
Big thanks! All data read is correct. :)
  • datalog.rar
