Hello, there is a thing called AUX in temperatures and it's constantly increasing up to 100-110C just after 20 minutes of gaming. All temperature monitor programs are showing exactly the same value, it's running at 50-60°C even on idle. I guess that should be on load actually. These temps will literally fry my motherboard. I can only play games for 1 hour because the temperature seem to hit even 120°C if I go further. Nothing is overclocked on my system and my case airflow is perfectly fine, also using an aftermarket cpu cooler. All other temps are below 40°C but this is absurdly high. Some people say this is an invalid value and should be ignored, some say that these temperatures are motherboard's VRM temps. I think the latter is true because when I touch that area on the other side of the case, I can already feel it's pretty hot.
MSI support said that they checked the bios code&circuit and couldn't find that sensor in bios so it could be virtual temp from the software. BIOS and MSI Control Center only showing cpu&system temps which are fine, but other software such as HWInfo, HWMonitor and Speedfan show this temp. And like I said, I can actually feel the heat with touching the other side of the case. It's burning like hell. And it doesn't always show high, constant values or odd temps like negative or below ambient temperature. It just heats like a regular computer part while in game, but never stops, overheating up to 100C immediately. Then slowly cools down when I exit the game. Please help me I can't even play games for 1 hour..
My system:
MSI P67A-G45 (B3)
i5 2500k @stock /w CM Hyper 212 EVO
Corsair Veng. 2X4 RAM
Silverstone 700W PSU
[attachment=1390]
My system:
MSI P67A-G45 (B3)
[attachment=1390]
