MSI Z490 Unify Die Sense Voltage Readings
Yaqy123
I am a current owner of the MSI Z490 Unify and i was wondering if it was possible for hwinfo development team to work on a VR OUT reading in hwinfo for this board, as it does have the controller capable of outputting VR OUT voltage readings (Die Sense) which are much more accurate than the Vcore Readings on the software which use VCC Sense voltage readings.
I'm sorry, but I currently don't have information about this VRM solution.
Hi Martin!
This board should use the Intersil 69269, the same VR as on the Gigabyte Aorus Master/Xtreme, etc.
So it supports VR VOUT and monitoring like the Gigabyte board that you added.
The meg ace and godlike I believe use the exact same VR :)
