solitarymassacre
As you can see in my screenshot, my Thermal Throttling (HTC) and (PROCHOT EXT) both have a thermal throttle "Yes" applied.
From my understanding, Thermal Throttling (HTC) is "HTC stands for Hardware Thermal Control. If it reports "Yes", it means the CPU is overheating." But I am confused because my die temps never went above 100C which is my max temp. Are the die temps at a lower threshold than the TjMax temps?
I also noticed it says my Thermal Limit percent is at 69.5, but my CPU Tctl/Tdie is only at 64.5, could this mean that if my die temps get too hot a Thermal Throttle (HTC) is thrown?
The other one is the Thermal Throttling (PROCHOT EXT), this is "something else" if this is the only thing flagged. But since I also have HTC flagged, this means it could be the die itself?
I am wondering if CPU die alone can issue a PROCHOT but the CPU cores (PROCHOT CPU) be completely fine. Does that make any sense? I am not super familiar with how all this connects and works.
In a GPU benchmark, you can also see my super inconsistent CPU freqs, my guess is due to the DIE temps,
My question is this - does HTC and PROCHOT EXT get flagged if the die gets too hot? Or is something else throttling my hardware?
Thanks!
Thanks!
