Need help with configuring Rainmeter
trinix
Hey,
I'm having trouble configuring a Rainmeter monitor extension and would appreciate some assistance.
I've installed the extension and want to customize it. I've also installed HWinfo 6.42 to keep the shared memory view active. I can open the viewer, but I'm now struggling with the configuration. Specifically, when I try to input the CPU ID into the Rainmeter config for certain modules, it doesn't work. I also tried the other ID 0x1000007.
I've searched online for a solution for several hours without success. Any help you can provide would be greatly appreciated. Thank you for your time.
Thanks for helping me out, i will do as you say :)
Im working on my PC the last weeks like a maniac, to be able to reinstall a clean Win 11. Before i could do that, i needed to replace the RAM and set the correct timings, which i then had to stresstest, that took almost two weeks, after that i could finally install everything, and after another week I do have almost every driver perfectly tuned and installed including all the peripherials, the only thing that is now missing is the weatherapp from rainmeter and a couple of weeks until my custom mod RAM Heatsink arrive. I started this build 8 years ago, and replaced everything with the exception of my Mainboard a x370 Asrock Taichi and the PSU an EVGA 750 Watts, to see my PC working so crispy and snappy, is like a miracle to me, to bad I couldnt get the Dashboard https://visualskins.com/skin/dashboard-18 to completly run, i do like the esthetics, but its only the weather plugin :) and looking back im kinda proud of what i achieved. Thanks again for your help, i couldnt have done it alone, places like this, will always be the real internet to me.
