Martin,
Still playing around here in this lab and found a problem - not sure if you can fix it but just posting it here anyways.
Connecting to a server with web / java based KVM client with lots of sensor lines to display. The sensor window is sized to the height of the screen (bottom of window is at the bottom of the screen behind the task bar) but when resizing it I noticed there's no buttons / options at the bottom of the window.
So I'm not sure if it's a KVM client thing or too many sensor lines.
Attached is what I see.
Thanks.
Thanks.
