Open fan control when...
Silentfan
I want to open the fan control, when the RPM-value from "GPU" (DELL EC) gets the value "2000". Is that possible?
P.S. I know this function: OpenFanCtrlMin=1 (In my case, that doesn't help).
Thanks in advance.
Best
Silentfan
I have a solution:
I configured an alert for the RPM value and when this value is reached, I start a second HWiNFO instance (32 Bit) with OpenFanCtrlMin=1. It works perfect!
The many features are great! :)
Silentfan
Now I use three (automatically starting) consecutive HWiNFO64-sessions. Realized trough (automatically starting) reg-imports (different alerts) and ini-copy-executions (fan-control off or on). Realized with invisible batch files (exe as result).
Silentfan
I have a problem: a later HWiNFO64-start (during gaming) minimized games to desktop (only in fullscreen-mode, not in windowed-/borderless-mode) . My .bat or. exe files are silent, that can`t be the reason.
Do you have any idea? I think it`s your fancontrol. Workaround: gaming in borderless-mode.
Thanks in advance.
Best
