pro version
Tomper
Is the pro version monthly payment or do you pay once and never agian ? i cant see if it says anywhere
Volodesi
Is it possible to deactivate one of the five PC's if you need to reinstall? I reinstall quite often and would like to use the Shared memory feature... I don't believe it would be worth it if I can't pull back one of my five uses if I need to reinstall.
Volodesi
Is this possible to do this on the site if it's not possible to uninstall/remove from the machine due to something like a messed up Windows install?
In such case the license deployed is considered as inactive and can be deployed on another system.
