romanovskis
I am using HWiNFO64 5.12-2740 to manage fan on HP 2530p. First of all, big thanks for this functionality, it is a lifesaver. I want to report something, that happens seemingly randomly, but almost everyday. Sometimes after reboot or after sleep resume, ExtTemp shows 255.9C and fan rpms 0, sometimes both disappear. It could be somehow related to RightMark CPU frequency mgmt utility, but I am not 100% sure, because it happens without it too. I just noticed that after reboot, hwinfo first shows normal values for Temps/FanRpms, but looses it after several seconds after start of RMClock.
As I run it in sensors-only mode, it does not generate reports in html/txt, only debug logs. Please see gdrive link for 8 debug logs below. https://drive.google.com/folderview?id=0B_JhIAmG1wOvR2FYbFdfVUFLOEE&usp=sharing
1st time, I enabled debugging, restarted HWiNFO and it came up without fan info
2nd time, I quit hwi, sleept/resumed and starte hwi, this time both temp and fan info was OK
3rd time, rebooted laptop, hwi started without both MB/Ext temps and fan
4th time, quit hwi, start hwi - temps came back, no fan rpms
5th time, sleep/resume (not quitting hwi) - temps became 255.9, no fan
6th debug - quit hwi, start hwi - both temps and fan OK
7th debug - quit hwi, start hwi - tempsOK, fan missing again. (That happened when FAN was down - 0 rpm, set by hwinfo during 6th debug run. Could it be the case that if fan rpm=0, that it is not found?)
8th debug - without any sleep/resume, just restarting hwi, both temps and fanrpms are back (this time fan was at 2200rpm)
runs 4 to 8 are done without RMClock.
