Samsung M.2 NVMe drive temperature reading problem
sancoder
After an upgrade to 7.42-5030 I noticed temperature reading on Samsung NVMe drive is getting weird. To confirm I ran the old version 6.28-4200 and it performed as expected.
To illustrate I made 2 screenshots. Looks like reading of temperature sensor in the new version is getting lost (and previous reading used) most of the time.
Previous "Drive Temperature 2" is now "Drive Temperature 3", it's explained here:
Thanks for reply.
Let me elaborate. The test (Crystal Dist Mark) runs minutes. With the old version of HWINFO the reading value changes almost every time a reading is made. Look at the graph.
But if I run the latest stable version of HWINFO, there are only 3 changes of values during the whole time. That seems wrong.
I didn't include other graphs into screenshots, but CPU and MB temperature graphs update normally, not like a step function as is the case with Samsung NVMe.
Ah, I see. Frequency of SMART polling has now been reduced by default to avoid too frequent queries to the disk which might in some cases result in spin up/down.
You can adjust the polling rate by going into Sensor Settings and change the "Disk S.M.A.R.T. every" value. By default this is every 100 cycles, so 100*2 seconds.
Given the reason for this change is HDD specific, is it possible to do this for HDD only?
I would speculate that in the future systems with HDD become less and less frequent.
On the other hand, defaults should be both safe and simple. Introducing complexity [for default value] might not be a good idea.
Sorry in advance if it's been already discussed when this change was implemented.
