Shared Memory 12 Hour Limit Popup
Xanardi
When using HWiNFO in a Windows Server 2016 environment, a 12-hour limit pop-up for shared memory appears.
Shared memory is disabled in the HWiNFO configuration.
Zach
Xanardi
I am aware that Pro is required to use SHM for more than 12 hours.
I have SHM set to Disabled. Is it correct behavior to see popups in that state?
That's not expected, the warning should not appear if that option is initially disabled.
Try to disable the Shared Memory option, restart HWiNFO and make sure it's disabled.
Xanardi
When HWiNFO was restarted, the configuration was in a state of rollback.
We tried to perform a reconfiguration from initializing the settings.
Popups seem to no longer appear.
