Hood
I've been using this program with great success through several builds, and it's sensor data has always been very reliable, more so than any other program, and it's always up-to-date on the latest hardware. My only problem has been inconsistent behavior of the saved settings, in particular, when restarting, it doesn't remember to "add to tray" the 6 sensors that I want displayed there. It worked fine before, always showing the icons after the program started. I had the same problem a while back, using hw64_406, and when I updated to 408, it started showing the icons again every time the program started. Just now I tried 410, but problem persists. Has anyone else had this problem, and if so, how did you fix it? It's not a Windows setting, I have it set correctly in Windows.
