[solved] 7.14 missing group header values in shared memory viewers
Bzuco
Hi, after install 7.14(I jumped from 7.12) I am not able to find/read CoreVIDs(max. from all cores) and CoreClocks(max from all cores) values in shared memory viewers like RTSS or Rainmeter - HWinfo plugin memory viewer, ....
I tried also delete all HWINFO registry keys, but no luck.
In 7.12 everything was OK, 7.13 I did not test.
Bzuco
  • debug.7z
These group headers were intentionally removed from shared memory as they don't represent real sensors, but only average/min/max of the aggregated values.
It was causing some confusion, also with custom sensor order where these groups are not present.
Since all the aggregated values are exposed via shared memory it's easy to calculate your own average/min/max.
Bzuco
OK, thanks for clarification.
I can make current max from all cores freqv. in Rainmeter app, but it is still tricky, because I need to make individual measurements for each core and then comparison to calculate current max...and in RTSS I can not make this calculations at all, because their custom math syntax can be used just for adjusting one value(similar to HWINFO).
If it is somehow possible, let me someone know.
I will probably stay on 7.12, because current max from all cores are more important for me as individual core values.
You can create your own custom sensor with min/max:
