strange issue with crosfire
Txdk
i have a alienware m17x r2 with 2 5870 in crossfire and when i start hwinfo it reads both gpu but after 5-10 seconds the second gpu data is gone but if i game or activate the second gpu the data is back again until i stop gaming then the data is gone again
That's because of the AMD ULPS feature - when the secondary GPU is not used, it's switched off by the system to preserve power.
Txdk
it didnt show this behaver before windows 10 and gpu-z can read the info of the second gpu but hwinfo only shows it when its in use
You probably didn't have ULPS activated before.
This is normal behavior and HWiNFO doesn't force the secondary GPU to be online to preserve power. If GPU-Z reports values while the GPU is sleeping, then it's either forcing it to wake up each cycle, or reports fake values.
You can disable ULPS if you don't like it.
