Andy8583
Hey, so I recently built a new PC with these specs:
CPU: AMD Ryzen 5 5600G
iGPU: AMD Cezanne (I bought this all just before the GPU crash, so an APU made sense)
Mobo: Gigabyte B550M DS3H
RAM: Corsair LPX 16GB (2 x 8GB) DDR4 3600 C18 (PC4-28800) 1.35V
PSU: Seasonic S12III 650W
Memory: Mixed HDD and SSD
___
It works completely fine when running Chrome, or word processor and excel, etc, but the moment I start playing a game (any game) its like I'm on a timer and within 5-30 minutes the PC will just shut down. And I don't mean enter a shutdown sequence, I mean the PC will just go completely power off in an instant with no warning. Obviously, this is a bit disturbing since the build I made was focused on budget gaming and its a completely new build with all-new components (except the HDD which isn't new but also isn't broken or anything).
So I decided to install HWinfo to try and run some logs while gaming to see if I can work out what exactly is going on, I set the log-tick to 0.1 seconds too so that if something unexpected happened it would hopefully record as much as possible leading up to the crash.
The only problem is... I have no clue how to analyze these logs to diagnose whatever is going on, so I'm posting them here in the hopes someone can help explain why my computer keeps randomly shutting down after a play a game for a while.
I've already looked at the temperatures for the core since I suspected that might be where the problem was since games would actually use the iGPU but so far the temp seems to stay steady below 40 C and the rest of the logs use a lot of terminologies I'm unfamiliar with, and a quick check using line graphs of everything didn't seem to reveal anything to me, but then again I don't really know what I'm doing when it comes to analysis.
I'll try to answer any questions promptly, I really hope something in the logs can be useful in pointing me towards a solution, otherwise I have no clue what is wrong.
Also, in case I forgot to mention it, these logs end when my computer powered-off unexpectedly while playing Conquest of Elysium, which if you look up will be clear to see isn't exactly a graphics powerhouse of a game :/
___
