Here's the list of currently supported command-line parameters in HWiNFO64 Pro.
This interface is available only in the licensed version (HWiNFO64 Pro).
Code:
Usage: HWiNFO64 [-r|-c|-x|-h|-m|-l][LOG_FILENAME]
Automatically create a hardware-snapshot report file:
-r Create Text Report File
-c Create Comma-delimited Report File (CSV)
-x Create XML Report File
-h Create HTML Report File
-m Create MHTML Report File
Additional report parameters:
-utf8 Use UTF-8 encoding (otherwise ANSI per current locale)
Sensor logging:
-l Automatically start sensors with logging. Following additional arguments are possible:
-log_delay=n Start automatic logging with a delay of n seconds
-max_time=n Stop automatic logging after n seconds
-poll_rate=n Polling period in milliseconds
-log_format=n Specify log file format n:
default (no argument): Value name in header; "sensor name" and "value name" at end
1 = Single concatenated header with "sensor name|value name"
Example to automatically create a CSV Report File: HWiNFO64 -cMyLog.CSV
Example to automatically start sensor logging: HWiNFO64 -lMySensors.CSV
Example to automatically start sensor logging in single header format: HWiNFO64 -log_format=1 -lMySensors.CSV
