System tray
Fugeth
Zdravim,
nepamatuju si presne kdy, ale cca 1-2 updaty zpet prestal OS (W11) zobrazovat 2 ikony v system tray. Je tam vzdy pouze jedna, druha je "hidden" i pokud je ve Win nastaveny, ze maj zobrazovat obe dve ikony. Jedno je CPU a druhy GPU.
Nic strasnyho, ale je to otravny.
Zkousel jsem vypnout / zapnout ikony, ktere maji zustat v system tray atp., ale nepomohlo.
I don't remember exactly when, but about 1-2 updates ago the OS stopped displaying the 2 icons in the system tray. There is always only one, the other is "hidden" even if Win is set to show both icons. One is CPU and the other GPU.
Nothing terrible, but it's annoying.
I've tried turning off/on the icons that are supposed to stay in the system tray etc, but it didn't help.
Placement of "tray" (notification area) icons is completely controlled by Windows. Applications cannot specify if/where the icons are placed nor whether they are hidden.
Fugeth
So in other words, it's "Bill" that's broken, not you.
Well I was just surprised that it worked normally for months, maybe even more than a year, but currently Win only allows one "icon" from HWiNFO no matter what I set there.
