T_Sensor1 not present on 5.74 and higher
Nick the Slick
Hello. Just wanted to report that on my ASUS Z170-PRO, the T-Sensor1 sensor is no longer showing up in 5.74 and higher. It shows up fine in 5.72 though. I've read the threads and understand there are difficulties in dealing with the ASUS EC so I don't know if it was removed intentionally or not, but figured I'd report it just in case. I've attached the report files from both 5.72 and 5.74 (and I can do the latest version as well if necessary). It won't let me attach the debug files though for some reason? Let me know if you need those and how to get them to you. Here are the screenshots of it working in 5.72 and not working in 5.74 in case that helps:
  • DESKTOP-8SHTNHC 5.72.HTM
  • DESKTOP-8SHTNHC 5.74.HTM
There's a bug in HWiNFO in reporting some EC values for these series. It will be fixed in the next Beta build planned for release later today.
Thanks for reporting.
Nick the Slick
It is indeed fixed, thank you so much. I'd like to say I greatly appreciate you and this program and all the hard work that goes into it, it's second to none.
