I have been trying various options to see what happens with the default skins and although I have had some success with the results, lack of knowledge/understanding is limiting what I achieve.
If you could clear up a couple of points for me as searching through the documentation I haven't found the information that I need to resolve the issues I have. (Probably because I am a newbie).
I have a basic desktop PC so I don't need a bells and whistles skin, just something that I can use to monitor what is happening.
I am using the Illustro skin and have modified/extended the System area to include temperatures and fan speeds which I can see. However, getting the meters to display what is happening is proving difficult. I have found all the relevant settings in HWiNFO and inserted them into the relevant .inc file. The first question is that there appears to be various options on the format to use for these settings as the original texts in that file are different to what you would use normally? Help here would be appreciated.
Secondly, how does the System .ini file in the Illustro skin work with the .inc information, what is each entry looking for?
And finally, what is the format of the information in the System.ini file for the meters to work correctly to display temperatures and fan speeds? If there is a "beginners section" in the documentation, then I would be happy to run through it.
Thanks.
