Unreally big powers and 0 RPM fans
1) Another funny glitch, huge max core powers. Seen for first time. See attachment.
2) Chassis fans RPM sometimes "drops" to 0 RPM, but they actually are rotating.
How frequently do those invalid core powers occur? It would be great if you could catch that in a HWiNFO Debug File and then post it here.
Used program about 1.5 month, and seen for first time. I should to enable Debug mode in settings, and in case of bug close program and then post HWiNFO64.DBG file?
And what about 0 RPM? I see it only in this program, other monitors never indicating minimum of 0 RPM.
If you have seen that only once then it will be very difficult to capture in DBG. Note that running in Debug Mode constantly writes to disk a lot of data, so it's not recommended for long periods.
Which fan is showing 0 RPM, under which heading is it ?
Geek_Geekson said:
Chassis fans which connected to motherboard and controlled from motherboard (BIOS settings), via PWM or DC - no matter for glitch.
Such glitches can happen on those mainboard series. Are you sure that other tools don't show them, are the able to report min/max values read?
Yes, other tools that able to monitor min and max values - never show min of 0 RPM, during 2 months. But in this tool I see it very often.
What other tools have you used?
Are you running HWiNFO along with any other such tool when the drop to 0 occurs, or is it running alone?
AIDA64 (stability test window) and something else (don't remember). HWiNFO running alone.
This could be a collision when multiple tools are running together and other tools might be ignoring the 0 value.
To confirm this, please watch the value when you have only HWiNFO running and no other tools (including AIDA64).
No, I said that I see this glitch very often also when HWiNFO running alone, without any other tools. This example illustrates only that this glitch I see only in HWiNFO.
