Virtual Memory Load is at 97% in red, help?
Tehzi
Hey all!
My first post and here I am lowkey panicking as to why I have my virtual memory load in red as 97% Is this something to be concerned about?
It's not a serious issue, just means the programs running on your system are consuming a lot memory near your virtual memory limit.
You might review applications running and/or extending the virtual memory limit (page file).
Tehzi
Thank you for the response!
I mean at the time all I was doing was playing warzone.
However I need to note that I am on power saving mode with the power options being beat power saving state. So I was on 1,800MHz the few hours of playing warzone. I am not sure whether this makes an impact or not.
Tehzi
No, those settings are completely unrelated.
Hmm ok thank you, I mention this only because I have 32gb memory and all I was running was warzone in the background.
My apologies Martin I uploaded the wrong image. Hopefully this image helps.
Even at 97% virtual memory load the physical memory is at 50% so I wouldn't worry about this.
Tehzi
When I notice this happening again, what specifically should I look at?
Should I go into Task Manager and prioritise memory? I am curious to see what is taking up all of the virtual memory as I only have HWinfo on aside whatever game I am playing.
Tehzi
You should see in Task Manager which process is taking most of memory.
As I am seeing right now, the only active software I have opened myself is Warzone and it is currently using 9gb of memory. However it states 50% of my memory is being used although I have a total of 32gb.
Also to mention, my virtual memory load is gradually increasing the longer I am playing this.
